[mapguide-trac] #668: cartographic stylization engine throws error
with composite and line/area stylization at same zoom level
trac_mapguide at osgeo.org
Tue Aug 19 16:32:52 EDT 2008
#668: cartographic stylization engine throws error with composite and line/area
Reporter: jmanafi | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: General | Version: 1.2.0
Severity: minor | Keywords:
External_id: |
When using CompositeStylization along with either Line/AreaStylization to
theme a layer at the same zoom level, a 'Microsoft Visual C++ Runtime
Library' runtime error terminates the MapAgent.exe. The legendui.php file
is the reference that causes the error, and the legend icon for the
composite symbol is not displayed. Some times, when the error was thrown,
loading of the map would stop unless the error was cleared off of the
server.
If a layer, or single scale range, is only themed with composite rules,
then the legend images show up just fine and no error is thrown.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/668>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
