[mapguide-trac] #445: Ajax viewer hangs when zoomed in close
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 20 10:54:43 EST 2008
   Reporter:  jmanafi      |       Owner:
       Type:  defect       |      Status:  new
   Priority:  high         |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.0.0
   Severity:  major        |    Keywords:
External_id:               |
 When opening the fusion learn template, zooming in real close causes Ajax
 viewer to hang. I cold-booted machine, server started automatically,
 launched learn template and tested zooming.
 The map reloads in a split second normally, but when getting down to ~1:8,
 the viewer took minutes, and at ~1:4, the viewer would hang. The problem
 also occurred on a custom map, but at a higher zoom level.
 I am using a Windows XP SP2, Apache bundled, php development environment,
 with MGOS 2.0.0 RC4
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/445>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
