[mapguide-trac] #445: Ajax viewer hangs when zoomed in close
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 25 12:46:53 EST 2008
 Reporter:  jmanafi      |         Owner:
     Type:  defect       |        Status:  new
 Priority:  high         |     Milestone:
Component:  AJAX Viewer  |       Version:  2.0.0
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Comment (by jmanafi):
 We began testing our data upgrading to MGOS 2.0 RC4 without using the
 fusion library, and we are noticing the same issues. The AGG renderer
 actually causes mgserver.exe to lock up at small zoom scales; today it
 happened at 1:254, whereas the GD renderer has yet to lock up, but it
 still takes a good period of time to update the map extents. Compared to
 MGOS 1.2 with the same dataset, both renderers perform worse when zoomed
 to a small scale, where, otherwise, they take only split seconds to update
 when zoomed far out.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/445#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
