[mapguide-trac] #627: MgAgfReaderWriter or MgWktReaderWrite
performs horrendously on large Polygons
trac_mapguide at osgeo.org
Thu Jul 10 16:50:47 EDT 2008
#627: MgAgfReaderWriter or MgWktReaderWrite performs horrendously on large
Polygons
Reporter: stevedang | Owner: stevedang
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: Web API | Version: 2.0.1
Severity: major | Keywords:
External_id: 934833 |
Attempts to process the large polygons result in the the Web Tier
consuming 97% of the cpu process when trying to read the polygon either in
SDF format using an MgAgfReaderWriter object or in WKT format using an
MgWktReaderWriter object. The largest polygon appears to process for more
than an hour or an hour and a half. The process has never been left to run
to completion as the API testharness calling the script always times out
before the execution of the script completes.
The ReaderWriters appear to process fine on small polygons, but the
performance is unacceptable on the large ones.
Note the priority on this is high because of the usability/performance
aspect of the defect. Technically the server does not crash during the
operation, but if something like this is executed first then the MapGuide
Web Tier may drop requests and become unusable for clients.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/627>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
