[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 11 06:36:07 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 I have found a bug that made the coordinates for a single tile become the
 current maximum extent, rather than the extent of the single image.
 I found it because you put the correct values besides the wrong ones in
 the config.
 I have put up a [http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
 preview release r3235] that should fix this.
 I am unable to display any of the images on my machine, but hopefully it
 works on yours.
 Please let me know if this fixes the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:23>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
