[mapguide-trac] #628: Linespace is increased after each occurrence
	of Map opcode '\P' to add a new line
    trac_mapguide at osgeo.org
    Fri Jul 11 12:55:18 EDT 2008
#628: Linespace is increased after each occurrence of Map opcode '\P' to add a
new line
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  high            |   Milestone:  2.1
  Component:  General         |     Version:  2.0.1
   Severity:  trivial         |    Keywords:
External_id:  1070173.01      |
 Create a new label with the labeltext: 'Test\PTest2\PTest3\PTest4\P'.
 After each line, the space between each line is increased, resulting in a
 huge line space between Test3 and Test4.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/628>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
