[mapguide-trac] #633: Studio login error with trunk build
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 21 00:05:08 EDT 2008
 Reporter:  mgluobin  |         Owner:
     Type:  defect    |        Status:  closed
 Priority:  high      |     Milestone:  2.1
Component:  General   |       Version:  2.0.1
 Severity:  blocker   |    Resolution:  fixed
 Keywords:            |   External_id:
Comment (by tomfukushima):
 I notice that this ticket says it is using 3247, but the change of
 "TotalActiveConnections" to "ActiveConnections" was done in 3241.  The
 returned XML says TotalActiveConnections still.  As this fix is in the web
 tier, you may need to update your web tier binaries and restart your web
 server to complete the fix.  Once the server returns <ActiveConnections>
 in the returned XML, then the changes have been integrated.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/633#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
