[mapguide-trac] #633: Studio login error with trunk build
trac_mapguide at osgeo.org
Mon Jul 21 01:52:20 EDT 2008
Reporter: mgluobin | Owner:
Type: defect | Status: closed
Priority: high | Milestone: 2.1
Component: General | Version: 2.0.1
Severity: blocker | Resolution: fixed
Keywords: | External_id:
Comment (by mgluobin):
Replying to [comment:8 tomfukushima]:
> I notice that this ticket says it is using 3247, but the change of
"TotalActiveConnections" to "ActiveConnections" was done in 3241. The
returned XML says TotalActiveConnections still. As this fix is in the web
tier, you may need to update your web tier binaries and restart your web
server to complete the fix. Once the server returns <ActiveConnections>
in the returned XML, then the changes have been integrated.
Thank you very much.I have finished.It works well.
Some days ago,i submit a ticket #614, but no answer returns.Can you give
some time to check it?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/633#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
