[mapguide-trac] #501: Buffer command does not buffer all
selected features
trac_mapguide at osgeo.org
Tue Jul 22 18:41:43 EDT 2008
#501: Buffer command does not buffer all selected features
Reporter: ronnielouie | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: General | Version: 2.0.0
Severity: major | Resolution:
Keywords: | External_id: 1057442
Comment (by ronnielouie):
The fix submitted for http://trac.osgeo.org/mapguide/changeset/3093 was a
temporary fix particular to the 2.0.x stream.
The correct solution is to fix the limitation issue in the !GenerateFilter
API. When this is done, the !GenerateFilters method will no longer be
available.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/501#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
