[mapguide-trac] #688: Polygon Label throws MgDbXmlException
trac_mapguide at osgeo.org
Tue Sep 2 13:33:05 EDT 2008
Reporter: crispinatime | Owner: ksgeograf
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
Editing a polygon and adding a label does not retain the size in the
editor and fails to create valid XML for saving.. e.g. below.
This is on the latest build.
A good feature would be to log exceptions to memory somewhere and then to
be able to retrieve them (for bug reports) through the Help/About
interface or a new Help/Exception item on the main menu.
Cheers - Crispin
<Label>
<Unit>Meters</Unit>
<SizeContext>MappingUnits</SizeContext>
<Text>FeatId</Text>
<ForegroundColor>000000</ForegroundColor>
<BackgroundColor>ffffff</BackgroundColor>
<BackgroundStyle>Transparent</BackgroundStyle>
</Label>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/688>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
