[mapguide-trac] #688: Polygon Label throws MgDbXmlException
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 2 16:07:55 EDT 2008
 Reporter:  crispinatime  |         Owner:  ksgeograf
     Type:  defect        |        Status:  closed
 Priority:  low           |     Milestone:
Component:  Maestro       |       Version:
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Thank you for reporting that. I had just fixed some issues with labels,
 but had not seen the problem with the size.
 I have fixed this and put up a preview (r3300):
 http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
 If the problem is not fixed in that version, please reopen this ticket.
 I have also implemented your suggestion to put in a "Last exception"
 viewer in the help menu. It does not yet work for all exceptions, but does
 work for "Save" exceptions, like the one you reported.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/688#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
