[mapguide-trac] #690: Deleting a Group from a MapDefintion breaks the map
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 8 10:02:00 EDT 2008
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 When removing a Group from a MapDefintion, the layers in the group are not
 removed from the map. Since the groups are missing, it can no longer be
 edited.
 This fix should both make sure that the layers are properly removed, and
 make sure Maestro can open a broken MapDefinition.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/690>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
