[mapguide-trac] #691: Ask the user if they want to update
references when moving or renaming resources
trac_mapguide at osgeo.org
Mon Sep 8 10:04:38 EDT 2008
#691: Ask the user if they want to update references when moving or renaming
resources
Reporter: ksgeograf | Owner: ksgeograf
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
After renaming or moving a resource Maestro will start to update
references. In some cases this is annoying, and Maestro should ask the
user if they want to update references or not.
This fix should also move the "UpdateReferences" call from being object
based to being Xml based, as it is both faster, and less likely to remove
data from the xml files.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/691>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
