[mapguide-trac] #520: Out of memory. bad allocation Errors
using Tiled Map
trac_mapguide at osgeo.org
Tue Sep 9 02:25:00 EDT 2008
#520: Out of memory. bad allocation Errors using Tiled Map
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Tile Service | Version: 2.0.0
Severity: major | Resolution:
Keywords: | External_id:
Comment (by zspitzer):
still getting this on 2.0.1... just using managed SDF's and SHP's
I have changed both providers to be pooled...
I gets lots of these type of errors.... the dataset for the map is big,
all of Australia...
Error: Out of memory.
bad allocation
StackTrace:
- MgTileServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\tile\TileServiceHandler.cpp
- MgOpGetTile.Execute line 150 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\tile\OpGetTile.cpp
- MgServerTileService.GetTile line 263 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\tile\ServerTileService.cpp
- MgByteSink::ToFile line 245 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\common\foundation\Data/ByteSink.cpp
Out of memory.
bad allocation
Error: Failed to stylize layer: Apr 08-ABORIG_SA
An exception occurred in FDO component.
SDF spatial index error.
StackTrace:
- MgMappingUtil.StylizeLayers line 775 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\mapping\MappingUtil.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/520#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
