[mapguide-trac] #693: PHP and ASP AJAX viewer fixes needed for
simple search on NULL values - MgProxyFeatureReader.GetProperty
line 448
trac_mapguide at osgeo.org
Wed Sep 10 16:54:47 EDT 2008
#693: PHP and ASP AJAX viewer fixes needed for simple search on NULL values -
MgProxyFeatureReader.GetProperty line 448
Reporter: cgountanis | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: AJAX Viewer | Version: 2.0.1
Severity: blocker | Keywords: IsNull MgProxyFeatureReader GetProperty AJAX Viewer
External_id: |
AJAX Viewer Fixes for PHP and ASP.NET - Value for property is null. -
Will these changes or something like this be implemented in the next
release of the basic AJAX viewer? We really should not have to edit
the ajaxviewer* code every implementation. Causes many problems with
services packs updates and organization.
PHP - Add if statement around the switch($propType) area.
Line 158
if ($features->IsNull($propName))
$val="(null)";
else
ASP.NET - Add if statement around the switch (propType) area.
Line 163
if(features.IsNull(prop))
val = "(Null)";
else
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/693>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
