[mapguide-trac] #693: PHP and ASP AJAX viewer fixes needed for simple search on NULL values - MgProxyFeatureReader.GetProperty line 448
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 10 17:40:49 EDT 2008
 Reporter:  cgountanis                                           |         Owner:
     Type:  defect                                               |        Status:  new
 Priority:  high                                                 |     Milestone:  2.1
Component:  AJAX Viewer                                          |       Version:  2.0.1
 Severity:  blocker                                              |    Resolution:
 Keywords:  IsNull MgProxyFeatureReader GetProperty AJAX Viewer  |   External_id:
Old description:
> AJAX Viewer Fixes for PHP and ASP.NET - Value for property is null. -
> Will these changes or something like this be implemented in the next
> release of the basic AJAX viewer? We really should not have to edit
> the ajaxviewer* code every implementation. Causes many problems with
> services packs updates and organization.
> PHP - Add if statement around the switch($propType) area.
> Line 158
> if ($features->IsNull($propName))
> $val="(null)";
> else
> ASP.NET - Add if statement around the switch (propType) area.
> Line 163
> if(features.IsNull(prop))
> val = "(Null)";
> else
New description:
 !MgProxyFeatureReader.!GetProperty line 448
 Line 158
 $val="(null)";
 else
 Line 163
 val = "(Null)";
 else
Comment (by jbirch):
 minor formatting
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/693#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
