[mapguide-trac] #693: PHP and ASP AJAX viewer fixes needed for
simple search on NULL values - MgProxyFeatureReader.GetProperty
line 448
trac_mapguide at osgeo.org
Thu Sep 11 16:59:45 EDT 2008
#693: PHP and ASP AJAX viewer fixes needed for simple search on NULL values -
MgProxyFeatureReader.GetProperty line 448
Reporter: cgountanis | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: AJAX Viewer | Version: 2.0.1
Severity: blocker | Resolution:
Keywords: IsNull MgProxyFeatureReader GetProperty AJAX Viewer | External_id:
Comment (by tomfukushima):
Thanks for suggested fix. I had to rework it so that it didn't have
constant strings (globalization) and also added it to the Java
environment. As there are no steps or data to reproduce the problem, I
will have to rely on someone to test this.
1. Please put the "en" file in the !WebServerExtensions/www/localized
folder.
1. Put the .php/.asp/.jsp file in the
!WebServerExtensions/www/mapviewerphp or mapviewernet or mapviewerjava
folder (depends on your install).
Once I have all three versions verified, I will get it reviewed further
and submit. If you are testing it please make sure you have a case where
the "(Null)" strings show up.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/693#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
