[mapguide-trac] #912: Installer: IIS7 Custom Action contains
defects
trac_mapguide at osgeo.org
Sat Apr 4 18:10:14 EDT 2009
#912: Installer: IIS7 Custom Action contains defects
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Installer | Version:
Severity: major | Resolution:
Keywords: | External_id:
Comment (by jbirch):
I think I've puzzled out in my head why this isn't working.
The current CAs are being executed in immediate mode because in deferred
mode the installer properties (such as the install location) are not
available. However, in immediate mode the files haven't been copied to
the destination yet so the IIS config tool can't create web.config files
in those directories.
I believe that using type 51 CAs is the only way of dealing with this
without hard-coding the parameters, so I'll go ahead and make those
changes to use the WiX built-in CAs and remove the IIS7 custom action
project from the build, etc.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/912#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
