[mapguide-trac] #954: Installer: Add top-level component so that CS-Map doesn't have to go in default location
MapGuide Open Source trac_mapguide at osgeo.org
Sat Apr 4 18:14:19 EDT 2009
default location
   Reporter:  jbirch     |       Owner:  jbirch
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  2.1
  Component:  Installer  |     Version:  2.1.0
   Severity:  major      |    Keywords:
External_id:             |
 Currently, CS-Map will always be installed in the default location because
 we don't have a configuration option for it.
 The three options are:
  - expose CS-Map in the UI and allow the user to configure the location
  - create an additional screen for the user to select the base
 INSTALLLOCATION
  - create a top-level component that allows the user to select the base
 ISNTALLLOCATION from the feature tree.
 I prefer the third option.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/954>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
