[mapguide-trac] #955: KML and KMZ mapagent operations broken
with Google Earth 5
trac_mapguide at osgeo.org
Sat Apr 4 21:59:59 EDT 2009
#955: KML and KMZ mapagent operations broken with Google Earth 5
Reporter: amorsell | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: Map Agent | Version: 2.0.2
Severity: critical | Resolution:
Keywords: kml,kmz,google | External_id:
Comment (by jbirch):
The first problem is a duplicate of #850 . We could work around it, but
the workaround is a hack that doesn't make a lot of sense, and I would
prefer to see whether the release version of Google Earth 5 (I've been
assured that there will be one this time) addresses this bug.
If you watch those operations in Fiddler (you'll have to use the machine
name instead of localhost, or Fiddler won't see them) what shows up (or
not) in the first case?
In the second case, if you rename the kmz to zip and extract it, what does
the KML file inside of it look like?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/955#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
