[mapguide-trac] #957: Doesn't check for computer configuration, to see if there is the right .NET inveroment
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 7 14:57:37 EDT 2009
inveroment
 Reporter:  nimcnaan   |         Owner:  nimcnaan
     Type:  defect     |        Status:  new
 Priority:  low        |     Milestone:  2.1
Component:  Installer  |       Version:  2.1.0
 Severity:  trivial    |    Resolution:
 Keywords:             |   External_id:
Changes (by jbirch):
  * component:  General => Installer
Comment:
 Are you saying that it doesn't detect that .Net 2.0 is installed during
 the installer process, or that it doesn't configure the web applications
 to run under 2.0 when integrating with IIS, or something different?  What
 are the symptoms you're seeing?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/957#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
