[mapguide-trac] #957: Doesn't check for computer configuration,
to see if there is the right .NET inveroment
trac_mapguide at osgeo.org
Wed Apr 8 01:22:11 EDT 2009
#957: Doesn't check for computer configuration, to see if there is the right .NET
inveroment
Reporter: nimcnaan | Owner: nimcnaan
Type: defect | Status: new
Priority: low | Milestone: 2.1
Component: Installer | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: | External_id:
Changes (by jbirch):
* cc: jng, jbirch (added)
Comment:
I just ran a test and got this result:
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -s
W3SVC/1/ROOT/mapguide
Start registering ASP.NET scriptmap (2.0.50727) recursively at
W3SVC/1/ROOT/mapguide.
The error indicates that this version of ASP.NET must first be registered
on the machine.
This is because on this image I installed IIS after !DotNet20. ASP.Net
was showing in the registry as being registered, but the IIS install had
walked on top of it.
To fix this, I ran the following;
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -ir
Start installing ASP.NET (2.0.50727) without registering the scriptmap.
Finished installing ASP.NET (2.0.50727) without registering the scriptmap.
This worked fine; after I ran it I was able to manually assign the
mapguide VDir the appropriate !DotNet version. However, I'm not entirely
convinced that we should do this as part of the installer.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/957#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
