[mapguide-trac] #480: Crash with MgInvalidStreamHeaderException
with GETTILEIMAGE (load test)
trac_mapguide at osgeo.org
Mon Apr 20 00:23:19 EDT 2009
#480: Crash with MgInvalidStreamHeaderException with GETTILEIMAGE (load test)
Reporter: zspitzer | Owner:
Type: defect | Status: reopened
Priority: high | Milestone:
Component: Tile Service | Version: 2.1.0
Severity: major | Resolution:
Keywords: out of memory , #520 | External_id:
Comment (by uvlite):
Hi Walt,
I tried to render the tiles our map on a 1GB windows server machine using
a most recent build from the build server.
The server falls over but the exception from FDO does not get propagated
to MapGuide correctly. I think this needs a bit of thought.
Generally, the behaviour of the server when memory runs out is bad because
the tileserver returns SUCCESS for wrongly rendered tiles!!
[Approach1] do a wait retry for each out of memory exception .... this
should already serialize memory requests sufficiently to make things
stable.
we could create a clever macro for all MEMALLOCS which does exactly this.
Maybe the allocator plugin for std library containers can be used for that
also.
[Approach2] at least propagate more meaningful errors from FDO to mapguide
so this can be dealt with correctly (e.g. return error message on the tile
but dont create the tile in cache) thats still better than wrong tiles.
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2009-04-20T13:30:01> 2088
Success: Server started.
<2009-04-20T14:04:41> 5212 192.168.99.99 Anonymous
Error: Failed to stylize layer: aug 06-ROADS - HWY
Cannot establish connection.
StackTrace:
- MgMappingUtil.StylizeLayers line 763 file
c:\ci\mapguide\build\mgdev\server\src\services\mapping\MappingUtil.cpp
<2009-04-20T14:07:28> 5540 192.168.99.99 Anonymous
Error: Failed to stylize layer: aug 06-ROADS - FWY
An exception occurred in FDO component.
An error occurred during SDF database access.
StackTrace:
<2009-04-20T14:07:29> 1768 192.168.99.99 Anonymous
Error: Failed to stylize layer: aug 06-ROADS - MAJ
StackTrace:
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/480#comment:12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
