[mapguide-trac] #968: Preview FeatureSource depends on Aggregates
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 20 03:38:05 EDT 2009
   Reporter:  ksgeograf  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  General    |     Version:  2.1.0
   Severity:  trivial    |    Keywords:  preview viewer aggregate OGR extent
External_id:             |
 The FeatureSource Preview has been updated to use the actual contents of
 the datasource for determining the preview extent. This is optimal for
 most FeatureSources, but some providers (like the OGR provider) does not
 support the requested aggregates.
 There should be a fallback method to use the spatial extent from the
 spatial context, if the aggregate function fails, as that is better than
 no preview at all (and actually correct for the OGR provider).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/968>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
