[mapguide-trac] #968: Preview FeatureSource depends on Aggregates
trac_mapguide at osgeo.org
Mon Apr 20 18:17:00 EDT 2009
Reporter: ksgeograf | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: preview viewer aggregate OGR extent | External_id:
Comment (by brucedechant):
There is code for the failback method still there.
I tried using the OGR provider to connect to a SHP file (Sample World
Countries) and I get back a useless SpatialContext. Here are the results:
<FdoSpatialContextList>
<ProviderName></ProviderName>
</FdoSpatialContextList>
In the above the provider isn't even listed. The interesting thing is that
I can use the feature source preview to see the attribute data just fine.
So at least the OGR provider appears to be partially working, but there
looks to be a bug in the OGR provider for returning spatial context
information.
So even if the SelectAggregates call fails there is no spatial context
information to fall back on and so the preview still fails.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/968#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
