[mapguide-trac] #968: Preview FeatureSource depends on Aggregates
trac_mapguide at osgeo.org
Tue Apr 21 03:25:14 EDT 2009
Reporter: ksgeograf | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: preview viewer aggregate OGR extent | External_id:
Comment (by ksgeograf):
Odd results, I tried it on a .TAB file, and got back a result (see below).
I see the fallback in showgeom.php, but it does not work because the
operation throws an exception. I will attach a patch.
<?xml version="1.0"?>
<FdoSpatialContextList xmlns:xsi="http://www.w3.org/2001/XMLSchema-
instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">
<ProviderName>OSGeo.OGR.3.4</ProviderName>
<SpatialContext IsActive="true">
<Name>Brugsgraense</Name>
<Description />
<CoordinateSystemName>PROJCS["unnamed",GEOGCS["unnamed",DATUM["Euref_98",SPHEROID["GRS
80",6378137,298.257222101],TOWGS84[0,0,0,-0,-0,-0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1.0]]</CoordinateSystemName>
<CoordinateSystemWkt>PROJCS["unnamed",GEOGCS["unnamed",DATUM["Euref_98",SPHEROID["GRS
80",6378137,298.257222101],TOWGS84[0,0,0,-0,-0,-0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1.0]]</CoordinateSystemWkt>
<ExtentType>Dynamic</ExtentType>
<Extent>
<LowerLeftCoordinate>
<X>678681.08834935876</X>
<Y>6178990.4343695538</Y>
</LowerLeftCoordinate>
<UpperRightCoordinate>
<X>702478.16620384331</X>
<Y>6202927.0221463479</Y>
</UpperRightCoordinate>
</Extent>
<XYTolerance>0</XYTolerance>
<ZTolerance>0</ZTolerance>
</SpatialContext>
</FdoSpatialContextList>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/968#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
