[mapguide-trac] #816: ODBC column editor not correctly persisting
key/geometry information
trac_mapguide at osgeo.org
Mon Jan 5 01:49:11 EST 2009
#816: ODBC column editor not correctly persisting key/geometry information
Reporter: jng | Owner: ksgeograf
Type: defect | Status: new
Priority: high | Milestone:
Component: Maestro | Version: 2.0.1
Severity: critical | Keywords:
External_id: |
When you configure a ODBC table to be a feature class, the following
happens:
1. The key field for a table (if specified) is not written to the
configuration xml (the configuration xml should have (xs:element ->
xs:key) elements for keys I specified)
2. If a z-component is specified for the geometry, it gets replaced with
the y-component.
3. If you reload the column editor with the updated configuration
document, it does not correctly load the X/Y/Z column information.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/816>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
