[mapguide-trac] #817: Improve Dispose thread safety for managed
.NET API
trac_mapguide at osgeo.org
Mon Jan 5 17:06:28 EST 2009
#817: Improve Dispose thread safety for managed .NET API
Reporter: waltweltonlair | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.2
Component: Web API | Version: 2.0.2
Severity: minor | Keywords:
External_id: |
The managed .NET API in MapGuide is essentially a wrapper around unmanaged
objects. Some of these unmanaged objects inherit from !MgDisposable
instead of
!MgGuardDisposable, and this can result in thread-unsafe behavior during
.NET garbage collection. A simple example illustrates this:
// get a managed coordinate system object from somewhere
MgCoordinateSystem mgCoordSys = ...;
// loop
for (int i=0; i<1000; ++i)
// get its catalog
MgCoordinateSystemCatalog mgCatalog = mgCoordSys.GetCatalog();
// do something with the catalog...
The !MgCoordinateSystem object is a wrapper around a separate unmanaged
coordinate system object, and the latter stores an unmanaged catalog
object. Inside the loop, each !MgCoordinateSystemCatalog object that gets
created is a wrapper around this same unmanaged catalog object. The ref
count of the unmanaged catalog object is incremented by one for each
!MgCoordinateSystemCatalog we create.
In this example each !MgCoordinateSystemCatalog goes out of scope at the
end of the loop's block, and therefore becomes a candidate for garbage
collection. At some point the garbage collector will kick in and collect
unused objects, and the ref count of the unmanaged catalog object is
decremented by one for each !MgCoordinateSystemCatalog that's collected.
By default garbage collection happens in a separate thread, and so it's
possible that garbage collection can take place at the same time as the
loop is being executed. So we can have one thread (the main thread)
executing the loop and incrementing the ref count of the unmanaged catalog
object, and another thread (the GC thread) decrementing the ref count of
the same object. Since the unmanaged catalog object inherits from
!MgDisposable, the calls to update the ref count are not thread-safe, and
therefore the example code above can lead to data corruption and/or a
crash.
The bottom line is that all unmanaged objects wrapped by managed objects
need to inherit from !MgGuardDisposable and not !MgDisposable.
Here's the list of managed objects whose unmanaged counterparts need to
change:
Web\src\DotNetApi\MgAgfReaderWriter.cs(12):public class MgAgfReaderWriter
: MgDisposable {
Web\src\DotNetApi\MgByteSink.cs(12):public class MgByteSink : MgDisposable
Web\src\DotNetApi\MgByteSource.cs(12):public class MgByteSource :
MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemCatalog.cs(12):public class
MgCoordinateSystemCatalog : MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemDictionaryUtility.cs(12):public class
MgCoordinateSystemDictionaryUtility : MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemEnum.cs(12):public class
MgCoordinateSystemEnum : MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemEnumInteger32.cs(12):public class
MgCoordinateSystemEnumInteger32 : MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemFactory.cs(12):public class
MgCoordinateSystemFactory : MgDisposable {
Web\src\DotNetApi\MgCoordinateSystemFormatConverter.cs(12):public class
MgCoordinateSystemFormatConverter : MgDisposable {
Web\src\DotNetApi\MgCoordinateCollection.cs(12):public class
MgCoordinateCollection : MgDisposable,
System.Collections.Generic.IList<MgCoordinate> {
Web\src\DotNetApi\MgCoordinateIterator.cs(12):public class
MgCoordinateIterator : MgDisposable {
Web\src\DotNetApi\MgCurvePolygonCollection.cs(12):public class
MgCurvePolygonCollection : MgDisposable,
System.Collections.Generic.IList<MgCurvePolygon> {
Web\src\DotNetApi\MgCurveRingCollection.cs(12):public class
MgCurveRingCollection : MgDisposable,
System.Collections.Generic.IList<MgCurveRing> {
Web\src\DotNetApi\MgCurveSegmentCollection.cs(12):public class
MgCurveSegmentCollection : MgDisposable,
System.Collections.Generic.IList<MgCurveSegment> {
Web\src\DotNetApi\MgCurveStringCollection.cs(12):public class
MgCurveStringCollection : MgDisposable,
System.Collections.Generic.IList<MgCurveString> {
Web\src\DotNetApi\MgGeometryCollection.cs(12):public class
MgGeometryCollection : MgDisposable,
System.Collections.Generic.IList<MgGeometry> {
Web\src\DotNetApi\MgGeometryFactory.cs(12):public class MgGeometryFactory
: MgDisposable {
Web\src\DotNetApi\MgLinearRingCollection.cs(12):public class
MgLinearRingCollection : MgDisposable,
System.Collections.Generic.IList<MgLinearRing> {
Web\src\DotNetApi\MgLineStringCollection.cs(12):public class
MgLineStringCollection : MgDisposable,
System.Collections.Generic.IList<MgLineString> {
Web\src\DotNetApi\MgPointCollection.cs(12):public class MgPointCollection
: MgDisposable, System.Collections.Generic.IList<MgPoint> {
Web\src\DotNetApi\MgPolygonCollection.cs(12):public class
MgPolygonCollection : MgDisposable,
System.Collections.Generic.IList<MgPolygon> {
Web\src\DotNetApi\MgHttpHeader.cs(12):public class MgHttpHeader :
MgDisposable {
Web\src\DotNetApi\MgHttpPrimitiveValue.cs(12):public class
MgHttpPrimitiveValue : MgDisposable {
Web\src\DotNetApi\MgHttpRequest.cs(12):public class MgHttpRequest :
MgDisposable {
Web\src\DotNetApi\MgHttpRequestMetadata.cs(12):public class
MgHttpRequestMetadata : MgDisposable {
Web\src\DotNetApi\MgHttpRequestParam.cs(12):public class
MgHttpRequestParam : MgDisposable {
Web\src\DotNetApi\MgHttpResponse.cs(12):public class MgHttpResponse :
MgDisposable {
Web\src\DotNetApi\MgHttpResult.cs(12):public class MgHttpResult :
MgDisposable {
Web\src\DotNetApi\MgLayerCollection.cs(12):public class MgLayerCollection
: MgDisposable, System.Collections.Generic.IList<MgLayerBase> {
Web\src\DotNetApi\MgLayerGroupCollection.cs(12):public class
MgLayerGroupCollection : MgDisposable,
System.Collections.Generic.IList<MgLayerGroup> {
Web\src\DotNetApi\MgMapCollection.cs(12):public class MgMapCollection :
MgDisposable, System.Collections.Generic.IList<MgMapBase> {
Web\src\DotNetApi\MgMeasure.cs(12):public class MgMeasure : MgDisposable {
Web\src\DotNetApi\MgReadOnlyLayerCollection.cs(12):public class
MgReadOnlyLayerCollection : MgDisposable,
Web\src\DotNetApi\MgServerAdmin.cs(12):public class MgServerAdmin :
MgDisposable {
Web\src\DotNetApi\MgSite.cs(12):public class MgSite : MgDisposable {
Web\src\DotNetApi\MgSiteConnection.cs(12):public class MgSiteConnection :
MgDisposable {
Web\src\DotNetApi\MgTransform.cs(12):public class MgTransform :
MgDisposable {
Web\src\DotNetApi\MgWebCommandCollection.cs(12):public class
MgWebCommandCollection : MgDisposable {
Web\src\DotNetApi\MgWebLayout.cs(12):public class MgWebLayout :
MgDisposable {
Web\src\DotNetApi\MgWebUiPane.cs(12):public class MgWebUiPane :
MgDisposable {
Web\src\DotNetApi\MgWebWidget.cs(12):public class MgWebWidget :
MgDisposable {
Web\src\DotNetApi\MgWebWidgetCollection.cs(12):public class
MgWebWidgetCollection : MgDisposable {
Web\src\DotNetApi\MgWktReaderWriter.cs(12):public class MgWktReaderWriter
: MgDisposable {
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/817>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
