[mapguide-trac] #1525: SHP Load Procedure coord system button not
wokring
trac_mapguide at osgeo.org
Tue Nov 16 08:31:03 EST 2010
#1525: SHP Load Procedure coord system button not wokring
Reporter: andrewd | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version: 2.1.0
Severity: minor | Keywords:
External_id: |
Using Maestro v3.0.0.5334, create an SHP Load Procedure. Then try to click
on the button in the "transformation" section, to adjust the coord
system....it doesn't work - it just does nothing. This had worked in 2.x,
although the coord system chosen tended to get ignored anyway.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1525>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
