[mapguide-trac] #1526: Layer drawing order up/down problems
trac_mapguide at osgeo.org
Tue Nov 16 08:58:01 EST 2010
Reporter: andrewd | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version: 2.1.0
Severity: minor | Keywords:
External_id: |
Sorry for the generic subject - but I'm trying to cram in 2 bugs here,
really...
In v3.0.0.5334, edit a map, switch to "layers by drawing order" and then
select a layer and use the up/down arrows. The item selected will deselect
after each press, meaning you have to reselect the item before each press.
An additional bug in this spot (or maybe just missing feature, to date):
it seems as though you can drag layers here, but you can't actually seem
to change the order. It won't actually allow the layer to be dropped
anywhere on this screen.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1526>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
