[mapguide-trac] #1778: "Show Long Theme" doesn't work in basic weblayout
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 12 01:09:14 EDT 2011
   Reporter:  liuar        |       Owner:  liuar
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  trivial      |    Keywords:  Show Long Theme, Legend
External_id:  1393349.01   |
 If a layer has more than 10 themes, only the first one and the last one
 display. Other theme icons will be replaced by ... [[BR]]
 Right click on the layer and select "Show Long Theme", other theme icons
 should display in legend.[[BR]]
 This function was broken due to the implementation of dynamic legend.
 [[BR]]
 To fix this, I will mark the iconWasRequested property of theme to false,
 and set it to true only if "Show Long Theme" is enabled. [[BR]]
 The only small affect is that there're two more duplicated (the first and
 the last) theme icons. I think that's acceptable.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1778>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
