[mapguide-trac] #1879: Maestro API - Fail to Create RuntimeMap
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 6 12:20:25 EST 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-4.0
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:  Maestro API
External_id:                |
Comment(by crispinatime):
 I put a try/catch in my code and it worked - though I also added the
 following to the catch{} block.
 With the Trace.TraceWarning() - I assume there is no feature to actually
 log an exception when using the API at runtime, such as to a file -
 because I can't get this to fail on my dev environment at all!
  C
 var propInfo = new PropertyInfo[0];
 this.IdentityProperties = propInfo;
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1879#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
