[mapguide-trac] #1879: Maestro API - Fail to Create RuntimeMap
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 6 23:53:07 EST 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-4.0
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:  Maestro API
External_id:                |
Comment(by jng):
 I'd really want to try to dig into the cause of why a Null Reference is
 happening. I haven't been able to reproduce this problem thus far. The
 TraceWarning() I put in means such exceptions if caught, will be logged to
 your VS window when debugging under VS, or you can configure ASP.net to
 display all trace output (http://msdn.microsoft.com/en-
 us/library/b0ectfxd.aspx)
 Setting identity properties to an empty array will just make the layer
 unselectable (regardless of the Selectable flag on it).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1879#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
