[mapguide-trac] #502: Feature Join rendering can be momentarily
broken due to incorrect case on secondary attribute
trac_mapguide at osgeo.org
Tue Dec 20 08:09:58 EST 2011
#502: Feature Join rendering can be momentarily broken due to incorrect case on
secondary attribute
Reporter: jng | Owner: brucedechant
Type: defect | Status: closed
Priority: high | Milestone:
Component: General | Version: 2.0.0
Severity: critical | Resolution: fixed
Keywords: feature join | External_id:
Changes (by jng):
* status: reopened => closed
* resolution: => fixed
Comment:
The original data that produced this problem was a SHP to MS Access join.
This type of join results in the problematic batch sorted block join
algorithm.
r6333 and r6348 means this such a join no longer use this algorithm.
Coupled with a workaround of ensuring all keys being joined are in the
proper case. This is pretty much resolved.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/502#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
