[mapguide-trac] #1790: Features with similar join property
values are not drawn in theme layer
trac_mapguide at osgeo.org
Tue Dec 20 08:18:03 EST 2011
#1790: Features with similar join property values are not drawn in theme layer
Reporter: migueaguilera | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Rendering Service | Version: 2.2.0
Severity: major | Keywords: join theme style
External_id: |
Comment(by jng):
Look at the data in the feature source preview, this will tell you if the
joined property values are lining up correctly (they should, but MapGuide
uses a buggy join algorithm which is known to produce incorrect results).
Are you on the beta program for AIMS 2013? The beta may include r6333,
which pretty much ensures the most optimal join algorithm is used for most
feature joins (SDF joined to any data source before r6333 did not use the
optimal algorithm)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1790#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
