[mapguide-trac] #1608: Web Extensions instant setup/configuration
utility
trac_mapguide at osgeo.org
Tue Feb 22 21:32:33 EST 2011
#1608: Web Extensions instant setup/configuration utility
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Build System | Version:
Severity: trivial | Keywords:
External_id: |
When building mapguide from source, the resulting build output is not
immediately usable. The server you can run straight away, but the web
extensions require a whole lot of manual setup as the web extension config
files are templated with lot of placeholder tokens (which the installer
would substitute in).
What we really need is an instant-config utility that auto-configures your
web extensions based on the current output directory of the web
extensions.
This would greatly speed up the code-test-debug cycle as we no longer need
to build/run the installer as a means of getting a functional web
extensions component for your freshly built binaries.
As a side-benefit, such a tool would allow for non-standard installation
that can be easily set up.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1608>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
