[mapguide-trac] #792: Excessive labeling with tiled maps
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 23 16:05:13 EST 2011
 Reporter:  zspitzer           |         Owner:
     Type:  defect             |        Status:  closed
 Priority:  medium             |     Milestone:
Component:  Rendering Service  |       Version:  2.0.2
 Severity:  critical           |    Resolution:  wontfix
 Keywords:                     |   External_id:
Comment(by gmele):
 Replying to [comment:3 jbirch]:
 > That sounds like a "won't fix" to me...
 Have you found any solution to this problem? I tried to enlarge the size
 of the tile but does not change. Moreover, the repetition of labels is
 within a single tile for each segment. The other solution proposed by zac,
 "combine all the individual features Into one" do not understand. I've
 tried to feature a single source of streets and the result is the same.
 My test results are more acceptable GETMAPIMAGE (not repeated so much)
 that GETTILEIMAGE, but I have to use tiles for obvious reasons of
 performance.
 Thks!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/792#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
