[mapguide-trac] #1733: ConvertResX.exe runtime error.
trac_mapguide at osgeo.org
Wed Jun 29 21:35:20 EDT 2011
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.5
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Snip of email I received
I am trying to convert the French files from the previous release 2.0 with
the following command “H:\MaestroDev-3.0\Localization>ConvertResX.exe
H:\MaestroDev\Localization\fr-FR\Maestro” but it always produces an error:
Exception non gérée : System.IO.DirectoryNotFoundException: Impossible de
trouver une partie du chemin d'accès
'C:\Users\Kenneth\Documents\Maestro\Localization\fr-FR'.
à System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
à System.IO.Directory.InternalGetFileDirectoryNames(String path, String
userPathOriginal, String
searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption
searchOption)
à System.IO.Directory.GetDirectories(String path, String searchPattern,
SearchOption searchOption
à System.IO.Directory.GetDirectories(String path)
à ConvertResX.Program.GetFormFiles(String basefolder, String language)
à ConvertResX.Program.Main(String[] args)
Do you have any idea where is the problem. How come ConvertResX.exe is
searching in 'C:\Users\Kenneth\Documents\Maestro\Localization\fr-FR'?
Disassembling the source reveals that this directory is hard-coded into
the application. Investigate the location of the original source.
Otherwise if all else fails. Rewrite the application from scratch using
the disassembled output as a guide.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1733>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
