[mapguide-trac] #1734: Convenience resource validator/factory setup
library
trac_mapguide at osgeo.org
Thu Jun 30 07:39:29 EDT 2011
#1734: Convenience resource validator/factory setup library
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-3.5
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The ExtendedModels AddIn currently does the work of registering
validators, serializers and instance factories for resource types whose
schema version is greater than v1.0.0.
This logic should be moved into its own library and the ExtendedModels
AddIn should call into that.
Any application referencing this assembly will implicitly be loading all
known ObjectModel assemblies.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1734>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
