[mapguide-trac] #1631: Map Definition Editor Defects and Loose
Ends (was: Map Definition Editor Defects)
trac_mapguide at osgeo.org
Mon Mar 21 06:31:02 EDT 2011
#1631: Map Definition Editor Defects and Loose Ends
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
Description changed by jng:
Old description:
> The following defects were observed with the Map Definition Editor in
> Maestro 3.0 beta 1:
> * Deleting layers does not clear the layer editor
> * Deleting folders does not clear the folder editor
> * Dropping a Layer Definition into a Base Layer Group will not add it to
> the group, but rather creates a new base layer group instead.
> * Drag/drop reordering of layers in a base layer group does nothing.
> * Drag/drop of an existing layer reference into a group ("Layers by
> Group" tab) does nothing.
> * It is possible for System.NullReferenceException to occur when adding
> the first layer to a Map Definition due to the fact that it naively
> assumes that obtaining the extents for the layer will always succeed.
> * Manual Scale List editor textbox does not allow the return keypress
> * Add a new validation rule: A map definition with 1 or more base layer
> groups, must have 1 or more finite scale ranges defined.
> * Editing the legend label incorrectly updates the layer display. This
> should be happening to the name component instead.
New description:
Maestro 3.0 beta 1:
* Allow deletion of elements by Del keypress
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
