[mapguide-trac] #1631: Map Definition Editor Defects and Loose Ends
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 21 07:09:29 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> The following defects were observed with the Map Definition Editor in
> Maestro 3.0 beta 1:
>  * Deleting layers does not clear the layer editor
>  * Deleting folders does not clear the folder editor
>  * Dropping a Layer Definition into a Base Layer Group will not add it to
> the group, but rather creates a new base layer group instead.
>  * Drag/drop reordering of layers in a base layer group does nothing.
>  * Drag/drop of an existing layer reference into a group ("Layers by
> Group" tab) does nothing.
>  * It is possible for System.NullReferenceException to occur when adding
> the first layer to a Map Definition due to the fact that it naively
> assumes that obtaining the extents for the layer will always succeed.
>  * Manual Scale List editor textbox does not allow the return keypress
>  * Add a new validation rule: A map definition with 1 or more base layer
> groups, must have 1 or more finite scale ranges defined.
>  * Editing the legend label incorrectly updates the layer display. This
> should be happening to the name component instead.
>  * Allow deletion of elements by Del keypress
New description:
 Maestro 3.0 beta 1:
  * ~~Deleting layers does not clear the layer editor~~
  * ~~Deleting folders does not clear the folder editor~~
  * ~~Dropping a Layer Definition into a Base Layer Group will not add it
 to the group, but rather creates a new base layer group instead.~~
  * ~~It is possible for System.NullReferenceException to occur when adding
 assumes that obtaining the extents for the layer will always succeed.~~
  * ~~Manual Scale List editor textbox does not allow the return keypress~~
  * ~~Add a new validation rule: A map definition with 1 or more base layer
 groups, must have 1 or more finite scale ranges defined.~~
  * ~~Editing the legend label incorrectly updates the layer display. This
 should be happening to the name component instead.~~
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
