[mapguide-trac] #1642: Change category view in New Resource Dialog
trac_mapguide at osgeo.org
Fri Mar 25 07:24:47 EDT 2011
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The Category view in the New Resource Dialog is a bit cumbersome as the
Available Templates view will only show templates for the selected
category. I'd guess most users won't realise that you can create a SQLite
load procedure because it's hidden in a separate category that most users
probably won't select.
Instead the Category View should be a checked list box, with the Available
Templates view being filtered on what's checked in the Category View. By
default, all categories should be checked meaning all templates are
visible.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1642>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
