[mapguide-trac] #1642: Change category view in New Resource Dialog
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 25 07:25:21 EDT 2011
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> The Category view in the New Resource Dialog is a bit cumbersome as the
> Available Templates view will only show templates for the selected
> category. I'd guess most users won't realise that you can create a SQLite
> load procedure because it's hidden in a separate category that most users
> probably won't select.
> Instead the Category View should be a checked list box, with the
> Available Templates view being filtered on what's checked in the Category
> View. By default, all categories should be checked meaning all templates
> are visible.
New description:
 category. For example, I'd guess most users won't realise that you can
 create a SQLite load procedure because it's hidden in a separate category
 (MGOS 2.2) that most users probably won't select.
 Instead the Category View should be a checked list box, with the Available
 Templates view being filtered on what's checked in the Category View. By
 default, all categories should be checked meaning all templates are
 visible.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1642#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
