[mapguide-trac] #1768: Implement RFC110 UI
trac_mapguide at osgeo.org
Fri Oct 21 04:32:43 EDT 2011
Reporter: yangte | Owner: Ted Yang
Type: task | Status: new
Priority: high | Milestone:
Component: Server | Version:
Severity: major | Keywords:
External_id: |
Comment(by yangte):
The ProfilingAPI_GUI_Part4.patch is mainly fixed some UI defects:[[BR]]
1. The alphabetical order of Map resource name should make the lower case
prior to uppercase [[BR]]
2. use "Infinity" to replace the '1000000000000' when display the scale
range [[BR]]
3. correct the the error message as "is no longer..." [[BR]]
4. when user reset the setting from the mapviewer if should display
warning as the setting changed [[BR]]
5. correct the recent setting time format [[BR]]
6. when the layer detailed information contains special chars the layer
detailed info will not be displayed[[BR]]
7. adjust the render time graph style[[BR]]
8. add the initial sorting to the layer information table
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1768#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
