[mapguide-trac] #1838: Rule reorder buttons in layer stylization throw an error
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 24 05:46:54 EDT 2011
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro trunk (2011-10-24)
 OS: Windows XP SP3
 In layer stylization if I try to change rules order using the buttons I
 receive the following error (translated back to english, so wording may be
 a little different)
 System.InvalidCastException: Cannot cast an object of type
 '<get_Rules>d__0' into type 'System.Collections.IList'.
    in
 Maestro.Editors.LayerDefinition.Vector.Scales.ConditionList.MoveSelectedRule(Boolean
 down) in
 z:\maestro_src\Maestro.Editors\LayerDefinition\Vector\Scales\ConditionList.cs:riga
 322
    in
 Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons.MoveRuleDownButton_Click(Object
 sender, EventArgs e) in
 z:\maestro_src\Maestro.Editors\LayerDefinition\Vector\Scales\ConditionListButtons.cs:riga
 253
    in System.Windows.Forms.Control.OnClick(EventArgs e)
    in System.Windows.Forms.Button.OnClick(EventArgs e)
    in System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
 button, Int32 clicks)
    in System.Windows.Forms.Control.WndProc(Message& m)
    in System.Windows.Forms.ButtonBase.WndProc(Message& m)
    in System.Windows.Forms.Button.WndProc(Message& m)
    in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
 What is bad of this bug is that UI does swap rules so user think that
 despite the error the reorder succeeded.
 Then  obviously layer stylization is different than expected looking at
 the UI.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1838>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
