[mapguide-trac] #1768: Implement RFC110 UI
trac_mapguide at osgeo.org
Tue Oct 25 23:58:07 EDT 2011
Reporter: yangte | Owner: Ted Yang
Type: task | Status: new
Priority: high | Milestone:
Component: Server | Version:
Severity: major | Keywords:
External_id: |
Comment(by yangte):
The ProfilingAPI_GUI_Part5.patch is mainly fixed some UI defects:[[BR]]
1. In the layer information table, the selected row should be highlighted,
and the move over highlighted is removed [[BR]]
2. For the scale, it should keep 4 decimals [[BR]]
3. 0 only is invalid for the scale value [[BR]]
4. if no filter was applied, then "No filter was applied to this layer."
should be displayed [[BR]]
5. refine some code structure, replace the <style>section and <script>
section in performanceReport.php
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1768#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
