[mapguide-trac] #1839: MapGuide Maestro and MapGuide Open Source 2.2
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 26 10:12:09 EDT 2011
   Reporter:  wrees     |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  medium    |   Milestone:  2.2
  Component:  Maestro   |     Version:  2.2.0
   Severity:  critical  |    Keywords:  maestro create layer
External_id:            |
 Hello,
 I've ran into a bug in Maestro when working with a MapGuide Open Source
 2.2 server.  I've tried using both Maestro 3.5.0 and Maestro 4.0.0 beta 2,
 both produce the same results:
 Version Information:
 Version: 4.0.0.6143
 MapGuide Version: 2.2.0.5703 (MapGuideOS2_2)
 When I attempt to create a new Vector Layer (doesn't matter which
 definition I use, they all produce the same error), I wind up with the
 following error message after selecting the Feature Source:
 Below are the error reports generated by Maestro.
 Maestro Error Report
 Version: 4.0.0.6143
 Date: 10/26/2011 10:02:33 AM
 Message: Index was out of range. Must be non-negative and less than the
 size of the collection.
 Parameter name: index
 Details: System.ArgumentOutOfRangeException: Index was out of range. Must
 be non-negative and less than the size of the collection.
    at System.ComponentModel.ReflectPropertyDescriptor.SetValue(Object
 component, Object value)
    at System.Windows.Forms.Binding.SetPropValue(Object value)
    at System.Windows.Forms.Binding.PushData(Boolean force)
    at System.Windows.Forms.Binding.UpdateIsBinding()
    at System.Windows.Forms.Binding.CheckBinding()
    at System.Windows.Forms.Binding.SetListManager(BindingManagerBase
 bindingManagerBase)
    at System.Windows.Forms.ListManagerBindingsCollection.AddCore(Binding
 dataBinding)
    at System.Windows.Forms.BindingsCollection.Add(Binding binding)
    at System.Windows.Forms.BindingContext.UpdateBinding(BindingContext
 newBindingContext, Binding binding)
    at System.Windows.Forms.Control.UpdateBindings()
    at System.Windows.Forms.Control.OnBindingContextChanged(EventArgs e)
    at System.Windows.Forms.Control.OnParentBindingContextChanged(EventArgs
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
 e)
    at
 System.Windows.Forms.Control.set_BindingContextInternal(BindingContext
 value)
    at
 System.Windows.Forms.ContainerControl.set_BindingContext(BindingContext
 value)
    at System.Windows.Forms.ContainerControl.get_BindingContext()
    at System.Windows.Forms.Control.get_BindingContextInternal()
    at System.Windows.Forms.Control.get_BindingContext()
    at System.Windows.Forms.SplitContainer.get_BindingContext()
 e)
 e)
 e)
    at System.Windows.Forms.ContainerControl.OnCreateControl()
    at System.Windows.Forms.UserControl.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.ControlCollection.Add(Control value)
    at Maestro.Base.Editor.LayerDefinitionEditor.Bind(IEditorService
 service) in d:\Workspace\maestro-
 trunk\Maestro.Base\Editor\LayerDefinitionEditor.cs:line 70
    at
 Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
 value) in d:\Workspace\maestro-
 trunk\Maestro.Base\Editor\EditorContentBase.cs:line 81
    at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
 IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
 trunk\Maestro.Base\Services\OpenResourceManager.cs:line 164
    at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
 trunk\Maestro.Base\Services\OpenResourceManager.cs:line 219
 followed by
 Version: 4.0.0.6143
 Date: 10/26/2011 10:02:40 AM
 Message: Object reference not set to an instance of an object.
 Details: System.NullReferenceException: Object reference not set to an
    at Maestro.Base.Commands.NewItemCommand.Run() in d:\Workspace\maestro-
 trunk\Maestro.Base\Commands\NewItemCommand.cs:line 64
    at ICSharpCode.Core.WinForms.MenuCommand.OnClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
 ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
 button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1839>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
