[mapguide-trac] #1980: ODBC connection with MGOS 2.2: Faulty configuration document in Maestro 4?
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 13 03:56:52 EDT 2012
   Reporter:  janvw    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by jng):
 I think I know why.
 I've been doing these configuration document changes against a trunk
 version of MapGuide, so FDO must've slipped in some breaking changes to
 how configuration documents are rendered and interpreted, so Maestro 4.0
 creates configuration documents that would be valid for MapGuide 2.4, but
 not for 2.2 and older releases.
 If you have time, download the 2.4 preview here
 (http://download.osgeo.org/mapguide/releases/2.4.0/Test/) and create the
 same configured feature source using Maestro 4.0.
 If this configured feature source works, then I'd have to think of how to
 generate compatible configuration documents for various versions of
 MapGuide (ugh!)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1980#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
