[mapguide-trac] #1922: AJAX Grouped Layers On/Off Enhancement
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jan 19 10:12:31 EST 2012
   Reporter:  crispinatime  |       Owner:
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  2.4
  Component:  AJAX Viewer   |     Version:  2.2.0
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by jng):
 This is currently not possible because the map image request has to be
 made to make layer/group state changes as well as getting back an image.
 Ideally there should be a separate operation for fiddling with layer/group
 states, or the GETDYNAMICOVERLAYIMAGE operation needs a do-not-render
 flag, so you can fiddle layer/groups visibility without needing a rendered
 result.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1922#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
