[mapguide-trac] #1930: Update build.bat to support VC10
compilation
trac_mapguide at osgeo.org
Fri Jan 27 01:21:33 EST 2012
#1930: Update build.bat to support VC10 compilation
Reporter: jng | Owner:
Type: task | Status: closed
Priority: low | Milestone:
Component: Build System | Version:
Severity: trivial | Resolution: fixed
Keywords: | External_id:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
Fixed r6455
To build using vc10 compiler run the following from the VS2010 command
prompt:
1. [setenvironment.bat vc10|setenvironment64.bat vc10]
2. [build.bat|build64.bat]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1930#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
